So give or take possible 300 hours of run time. That about ten months of drive time for most people. Plus your running in a more service controlled environment I hope. Using the right oils with bronze or brass is a plus. Most will just have any cheap crap oil installed unlike your race car.The bronze gear in my racecar has been in use since 2013. Over 1100 passes.
Geoff 2:
With a big block, the drive rides upward due to the counter clockwise rotation of the the helix. Riding upward retards the timing. A small block rotates clockwise so it drives downward. There is a cam button installed. There is no taper on roller cam lobes. So there is no reason for anything to flex forward or rearward.
Doug
Over the weekend, I shimmed the front of the timing cover. This seems to have solved the problem.
smart people on here
