Torqueflite 727 trans pan
GFuller
1:00 AM
Merryville, La.
I have had enormous trouble getting my transmission pan to seal completely. It is the original pan with no drain plug. I am ready to locate a new pan with drain plug and found one in Summit. Just wondering what is groups opinion on best pan to buy? Anyone have advice?
If it is your pan only leaking, take it off and hammer around the edges when the bolts go thru and make sure it’s flat. Shouldn’t have any issues after that. If someone has over tightened the pan bolts before it won’t seal
Got a pic of the pan rail? Post #2 is what I'm thinking too
George, be sure it’s not the O ring on the dip stick or the seal on the shifter mechanism. Clean everything thoroughly and check it to be sure it’s your pan. Sometimes it’s not the pan at all. Like mentioned above, make sure your pan is flat. Silicone on transitions is not your friend. IMO
Buy once, cry once. The B&M aluminum pan is nice and seals with cork. Made in the USA as well.
My street car has a B&M. Nice pan but it is HEAVY. And now a days way to costly. The current cost at Summit is $242. The racecar has a R46H stamped pan. Neither one leak a drop.
Just ordered two of those Amazon pans
Looks like it’s 3” deep
Already have the billet aluminum extensions
Cork or silicone o ring gasket
Thanx Scott
Thanx Scott
The 518 pan works well with the reinforced factory style gasket. My racecar has the same pan gasket afetr 10 years with numerous tear down checks.
Another common culprit is the shift selector seal.
Again be sure it's really the pan otherwise you're spending time and money for no improvement.
Shift selector seal
O ring for dipstick tube
Rear reverse band shaft with O Ring seal is the worse
Anyways these are all new - Rebuilt transmission five years ago
These areas look dry and clean
Old pan I guess
Thanx Scott
