Torsion bar RH & LH ?
429bossman
1:24 PM
Fresno CA
Is the a Right and Left torsion bar on a 70 Plymouth GTX. If so how do you tell . Thanks
Check the end, there should be a R and a L on them.
Usually the bars with the odd number goes on the left and an even number the right side. Some have a L OR R also. The third way was paint spots two on the left and one on the right.
Thank you I had a 50 -50 chance of guessing it right I installed it wrong . Fords are lot easier than mopars. :BangHead:
I've "heard" that if you put them in backwards they can break since they've always been twisted one direction (if used) and you suddenly twist them the other way.
