TQ Converter stall suggestions
tadam05
9:46 PM
Wainwright, AB, Canada
I need some advice on TQ Converter stall speed for my set up. Any help would be greatly appreciated.
This is my current engine/ car specs:
1969 Road Runner Hardtop-Approx. 3600lbs
-383 BB bored .030 over(388 ci)
-Forged Ross pistons-10.2:1 comp. ratio
-Edelbrock Performer RPM heads
-Edelbrock Performer RPM Intake
-TTI headers/exhaust w/x-pipe
-770 cfm Holley Dominator
-Comp Cams Xtreme Energy 274 Cam(hydraulic flat tappet)
- duration @ .050" 230/236
- valve lift 0.488/0.491
-Comp Cams Roller Rocker arms
-3.91 gear ratio
-BFG tires- 27" tall X 11/12" wide
This car will be used for street use mostly and drag raced at the track most weekends(1/4 mile)
Seems everybody has an opinion but none seem to be truly informed.
Thanks a bunch.
Call TCS
Call Torque Coverter Specialties in BC. Give them all the info and they will build you a converter that will work. All my buds around here use them for street and racing. They are very knowledgable and reasonably prices.
Number is 604-533-8675. I called them about my 440 setup and they were very good guys to talk to and they know what they are talking about. They will tell you what you need wether you end up using them or not.
cheers
Steve
