Mopar Hunter
Found this on the Fakebook.What do the Trick Flow 295cc heads flow?
I doubt that would make for a streetable motor, but I could be wrong lol
You're going to want to do some upgrades on that trans if you are anywhere near 600-700 hp. Most important would be a steel front drum for safety, your valve body should also have low band apply ,a drag sprag from cope or A&A ,good clutches, etc. I bought a TCI ( total crap inside) 700 hp "competition" trans for my 64', it didn't make 100 miles. Check out CRT -Cope racing transmissions. They have do it yourself packages they will give you some insight as to what you really want in your trans.Well as far as I know , other than the full manual valve body its a stock transmission with good parts in it to handle 700 horsepower. Stock input shaft, stock sprag.
The aluminum front planetary gear is another part, the splines can strip out with high HP. The heavier the vehicle, the more stress on the parts.You're going to want to do some upgrades on that trans if you are anywhere near 600-700 hp. Most important would be a steel front drum for safety, your valve body should also have low band apply ,a drag sprag from cope or A&A ,good clutches, etc. I bought a TCI ( total crap inside) 700 hp "competition" trans for my 64', it didn't make 100 miles. Check out CRT -Cope racing transmissions. They have do it yourself packages they will give you some insight as to what you really want in your trans.
