Trick flow cam ?
19 69 GTX
1:40 PM
Already have engine assembled. Just curious if tye Trick Flow cam that comes in there top end kit is able to run a mechanical fuel pump..I have rod in the hole but don't see any movement..?
I installed one. It had the eccentric. Used a comp pushrod but sounds like it's going to blow up, haven't started it yet.
Push the rod up with your finger and have someone turn it over
Kind of hard to believe it would be made without the eccentric cam.
I pushed it up in there and then turned engine and watched the rod but no movement at all..
Push the rod up tight against the cam with some pressure on the rod. The stroke is long and easy to miss the lobe. Don’t ask me how I know this…:BangHead: :thumbsup:
