trim molding mounting studs
PDFROGMAN
10:44 PM
Vernon NJ
previous owner of my sport satellite convert ground off the mounting studs on the rocker panels
any suggestions on how to replace them or even where to get something like that?
I do know that I can always screw the clips on
Thoughts?
Hello from germany.
I know some reviting pins from 1970/80s Opel/ GM cars.
Its the same system like on the mopars.
Rene
if the metal is too thin to weld,you can use a strong epoxy to attach either studs or bolts into place.
where do you get these riveting pins? I have searched everywhere
any body shop supplier will carry them and they should also be able to get the rivet head for them for your rivet gun ,if you where in the body work stage and had the stud gun they use to have those studs ,and you could weld them up and be done :headbang:
If you will have a problem to get the pins then let me know how much you need.
I will look how much i have.
Rene
thanks I will a bit banged up right now with food poisoning
previous owner ground all of them off I think there is 5 on each side
