Trying to date an AVS 4426S carb to known engine assembly date
craigerlitz
11:22 PM
Patton, PA
Hello everyone. I am looking for help from all of you. I have a 68 Barracuda with a 383 that is missing the original carburetor. I have some 4426S carbs with J and K stamped months. Neither one has a tag for the day. I am hopeful that one of you has a 68 383 Charger, Coronet, or Road Runner with an engine assembly date of 10-23-67. If your engine was assembled around 10-23-67, what are the dates of your engine assembly and on the tag on your carb?
Thanks,
Craig
So you have a J7 or a K7? So September/October...The general rule of thumb is within 3 months prior to actual build date. So either one will work and all you need is the correct calendar day/year tag. Just mate that with either carb.
Call Scott Harms at Harms carb to get a tag....
Yes, they are dated J7 and K7. I am looking for the correct or a realistic calendar day to have a tag made. Scott recommends Brian Brady to do the tags.
Thanks,
Craig
Thanks,
Craig
Realistic is somewhere in that range....no one could prove otherwise...
My 69 GTX was built in 10/68. Unfortunately, the carb is sitting on the motor on the dyno at the machine shop. It is the original carb and has the original tag and is restored. I should be getting the motor back next week and I can tell you the calendar day on that tag. I have pictures but not of the tag right now....
