Trying to find parts
moparfreak1980
4:48 PM
Ontario
I have a 75 Coronet have been searching the net looking for trunk and floor pans everywhere I have been B bodies stop at 1974. This has got me wondering are they close enough that I could make the 74 pans work or where can i find a set for it
Your 75's trunk should be very close to the 74's trunk.
However, might I suggest that if you need to replace your gas tank because its rotted or whatever, consider going with a 71-73 trunk pan.
Not only will the pan be easier to find reproduced or used replacement pan, the gas tank is MUCH cheaper and you will eliminate that hump in the trunk.
Oh the 73-74 cab floor pans should be pretty close to 75 as well.
71-72 are slightly different from the 73-74 due to the longer torsion bars for the ISO torsion anchor behind the trans cross member.
Hope this helps
I was pretty sure I would have to replace the fuel tank have not been under it in a while
