Trying to replace my reverse light lenses.
Heimedw
12:55 AM
Ontario
Just wondering if there is a trick to getting the reverse light bezels off. I removed the two nuts from inside the trunk and can't seem to get the bezel on the outside off? I don't want to brake anything so I thought I would ask for some help.
I would think it's just stuck on the gasket/grommet.
Are your tail lights seperate or a 500 with all of them on a bensil?
It look so just like your picture. Only had nuts on studs one on opposite corners.
Ok Tip for the next guy it's two studs in opposite corners and two screws hit behind foam in the other two corners. Just had to push the foam back to get at them.
