JR_Charger
Quick question - in this day of supply shortages and bad parts, which one of these brands would you go with?
Long question - follow my logic as I try to figure out which u-joint I need -
I have a 318/904/8 1/4 72 Charger.
Looking at the choices on Rock Auto - Link
I see the u-joints are determined by either the "bearing cap size" or the "outside diameter yoke span."
My bearing cap size is close to 1 1/16", which is 1.0625, so that means the 1.078" u-joints should work.
I'm not sure what "outside diameter yoke span" is. I measured my slip yoke -
I've got a 2 1/8" inside diameter, and there are a couple 2 1/8" or 2.125" outside diameter yoke options.
It seems likely the 1 1/8" bearing cap size and 2 5/8" outside diameter yoke u-joints are for more powerful cars than what I've got. The 1.078, 2.125 outside diameter yoke u-joints should be the ones I need?
