Under $300 disc brake conversion.
1967coronet
8:10 PM
Iowa
It was time for a brake job on my 67 coronet.
It needed pretty much everything 10" drums, cylinders, hoses , shoes the works.
I had read in mopar action Erinburgs article on the Scarebird brackets and parts list for a disc swap. So away I went. The brackets and hardware from scarebird along with parts list and instructions came in at $113 with shipping.
My local bill at my automotive for calipers , shoes, and hoses was $120.
A set of Ford/lincoln 10.5 rotors by raybestos off ebay was $41 So all in for $274.00
This is a manual not power set up sized to work with the manual master. I went with the 10.5 set up so I could retain my steel 14" wheels.
My master cyl. is in good shape so no change there.
With this setup you reuse your original hubs. My bearings and races were good and just needed trip through the parts washer and a repack. I had a pair of seals for the hubs.
I've had it out just around the block a couple times because of weather no real hyw. Test but the around town and pedal feel is great.
If needed I may have to install a proportion valve in the rear line but I will wait until spring and get some testing on a wet road ect.
Thanks! Nice write up. So which rotors exactly are these?
I could probably do 10 of these in a row, everyone is always asking.
91 lincoln mark V11.
The fit on the hub is tight , I did a little clearance on the hub hole with my die grinder and knurled bit, couple swipes around and she slipped right on.
Scarebird warns about the tight fit in the instruction sheet.
I thought that the Celebrity was only made until 1990?
I will look at the scarebird parts list. I whipped that out of the old memory bank ,
I know they are 90s celebrity I will ck that when I get home.
I spent some time (unsuccessfully) tying to see what other calipers there might be that would bolt up to the Scare bird brackets. I would use that kit except I don't want a signal piston caliper.
Thanks for the info. A disc brake conversion is in my future. I have a brand new master I bought for a large single piston caliper set up.
I see they offer another set up that uses Cordoba 11 3/4 rotors and the same calipers, for almost twice the money. How much difference would the larger rotor make with the same calipers and pads?
This one?
https://scarebird.com/index.php?route=product/product&path=64&product_id=158
If so, was that die grinder exercise because of this?
"We include the brackets, banjo bolts, cotter pins and hose locks. The rotors will require the center hole to be opened up on a lathe approximately 0.030". We can sell rotors ready fit for a modest fee: click here"
This one?
Yes Ed, looks like the same brackets I ordered.
I do not think it needed .030 more but I am sure different hubs and rotors are a bit different.
I only had to make a couple rounds inside with the bit and they slipped right on.
What "center hole" are we talking about here? Where the rear bearing race inserts? The front one?
