Robert Schaad
History for me. I had a trans leak on my BB with 727 trans. Fluid around trans gasket but Gasket is tight. No leak at shift linkage. No leak at dip stick tub. What is going on? Two times this happened and I found it. Just above the trans pan in the center at the back of the 727 trans is a PLUG. Some times it is a rubber plug. The Plug comes loose and leaks. Put some sealant on it and the leak stops. Hope that helps.
