Upgrading B Body Power drum brakes.
Azmotorhead
3:15 PM
Peoria AZ
I'm in the process of upgrading the power drum brakes on a 70 GTX. Putting Discs up front. Leaving the 11"drums in the rear.
I can't seem to find a definitive answer to"Do I need a new master cyl and Prop valve?.None of the brake conversion packages that are being sold come with a master or prop valve. Some old threads here and other boards say yes you end to change the master. Probably a good idea as I dont think the original master has a residual valve in the front circuit. It would be too easy to call Pirate Jack or another vendor but alas its the weekend.
You will probably need a dual-diaphragm booster and larger bore master cylinder. You may need a different proportioning valve or an adjustable valve in the rear circuit. In my experience a lot of heartache could be on the way.
Thanks CKessel. Good article with valuable info. I'll have to check the booster to see if its a dual diaphragm or single.
Your factory booster is a 9" single. If engine vac is good it will be fine. Just change the master to the disc/drum master for your car RAYBESTOS MC36283
Since you're in Zoney land, you may have access to many of those needed items at wrecking yards. DVAP maybe or others.
I bet. Any other more reasonable sources around?
