upper radiator hose swollen
paynegregory
1:07 PM
Arizona
upper radiator hose swells up at water neck about the size of a grapefruit on 318 engine
I would also do a few checks to find out the reason for the swollening....check & make sure your bottom hose isn't collapsing....Check radiator cap.16psi.... malfunction enough pressure to swell the hose...Maybe just a bad hose?
could pressure be building from a blown head gasket
took thermostat out and it still swell some
its been more than four hour so im seeking medical attention I need a machine doctor to reply
it's a bad hose..just replace it...I doubt it's a blown head gasket..this hose issue is common on small blocks
and put yer t-stat back in
so I think I should replace hose, cap and thermostat and see what happen
When there is no pressure in the system does the hose feel really mushy? If so it needs replacing. If it's like a new hose it could be several things. Bad radiator cap, holding too much pressure. Stuck thermostat, stuck closed and not allowing circulation. Bad head gasket, allowing compression to leak into the cooling system. Think simple, sounds like an old hose to me...
Yep, bad hose. Take out bad hose; put in good hose.
Good hoses do not swell from to much pressure they blow so it is likely just the hose that is bad
