popinsmoke
Greetings and thanks for taking the time to read this,
I purchased a 1978 Dodge Magnum, 360 2bbl W/Auto trans (904) the lean burn system has been removed and a knock off of the Mopar Performance Electronic ignition made by proform was installed in its place.
As I do with any car I buy used; I check the compression and change the oil and give it a tune up.
Compression was good so I changed the oil and preceded with the tune up as the car idled very poorly.
Checked the mechanical timing at it was 10 degree's, checked manifold vacuum and it was about 8 inches, so the hunt for the vacuum leaks began.
I chased the hoses with propane torch and ended up finding about 6 different leaks, replaced the offending hoses and checked vacuum again.
After replacing some leaking hoses the vacuum gauge would show 15 inches and had smoothed out some.
I have tried smoke, propane, wd-40 and blood sacrifice to find where it is still leaking, if I hand choke the carb the vacuum jumps to 24 inches and picks up rpm and runs smooth as glass.
WD-40 the intake gasket areas, base of the carb, checked brake booster fitting, I am running out of idea's of where to look?
Yes I posted this in another section but it doesn't see as much traffic, my apologies to the mods please feel free to merge the posts.
Thank you in advance for any and all advice.
