- 8:51 AM
- Jul 1, 2015
Never really worked on any "A" body units...cannot speak to that end. All the B and C bodies I've worked on had pressure balanced TXV valves.....plus the only other control devices was a high pressure switch on the receiver: it also functioned thru a second contact as a NO, pressure held it closed to prevent the clutch from engaging in the event of loss of refrigerant. But I'm sure there are...... variations ....... many people remove the EPR VALVE from the RV2 COMPRESSOR when converting to R134A.....without difficulty.........I beg to disagree. If the EPR valve is removed, the suction pressure at the evap, can keep going down, when at low load. Then you will have evap freezeup. It is required to have some method of maintaining evap pressure above "about" 32 psi. In many of the full size Chrysler products, this was done with the EPR valve. On other Chrysler products (mostely "A" bodies) evap temp was controlled with a thermostatic clutch cycling switch. When I built the refer truck units, I used the RV-2 compressor, with a roof mounted power condenser, and a Commercial walk in cooler evap unit with a switch to a 12v fan motor. We accheived a box temp of 34 degrees, and used clutch cycling with a room air sensing T-stat.
I agree on the GM compressors. However I did have some issues with the control valve on the V-5.
BOB RENTON
