steve from staten island
- 6:13 PM
- Sep 24, 2012
- staten island,ny
How much vacuum should a healthy stock 383 make? How much does timing affect vacuum and why? Thanks
Stock cam for a 383, 2 barrel engine. Timing is slightly advancedWhat cam is in it, is it installed straight up, advanced, or retarded ?
Not having a good seal on the cylinder during the intake stroke. In other words when that piston is moving down, and the intake valve is open, the only place it should be able to draw in air is through the carburetor. So, low vacuum can be caused by something like the exhaust valve being open longer (bigger cam/overlap), or a leaky valve/intake manifold/carb base.What exactly makes vacuum low.
I meant cam Timing, not ignition. Nevertheless, you should easily pull 18Stock cam for a 383, 2 barrel engine. Timing is slightly advanced
I think a large cam overlap will cause low vacuum as well.What exactly makes vacuum low.
