moper
Too rich is as bad as too lean. It sounds to me like you broke a ring or ring land. Engine will still run. Might not even smoke. But I'd test it.
What kind of money are ya talkin bout?
Previous owners wife claimed 14 to 1, but I find that hard to believe. I had a 451 running 13.5 to 1, that ran fine on 100 LL, Since I'm I'm at 5500 feet. That's like running 12 to 1 at sea level. A motor loses alot of power up here due to the rarified air. It has to compress a little before it even gets back to std atmospheric pressure. You can get away with a good point or more of compression up here in Colorado, compared to sea level.If your running 100LL fuel on a 14-1 @ 38 degrees it's got to be in detonation . May have damaged a piston or 8.
Ok, I'll try that too. I'll also check the fitting at the header for proper operation. Thanks!Good call Doug.
As said, leak it down.
If that checks out, try not running the vac-u-pan, and just run the breathers open.
Yea, that makes sense. I had the mufflers on for a short time, but opened it up to see how it would run. Prob happened then, just didn't notice it right awayVac-u-pan and mufflers often don’t work well together.
Yes, it IS a dual gauge set up. From Pittsburgh Tools, Harbor Freight Tools. I could hear it leaking past the rings on every cylinder.I’d be verifying the gauge by trying it on another motor that’s known to not have any issues.
Is it a dual gauge style tester?
If so, let’s see a pic of the gauges?
