RBCharger
I am assembling my 440 and have run into a few things on the valvesprings/cam. So 2x questions - which springs and which locks?
I have the Trick Flow 270 heads - the 801-C01. The valvesprings on the head are as follows:
1.460" O.D. dual spring with damper (TFS-16893)
120 lbs. @ 1.900" installed height
394 lbs. @ 1.175" open
390 lbs. per inch rate
.650 max lift
I have Comp cams 21-228-4, Specs are:
.545/.545 and 241 int./247 exh.
I have the Hughes 1.6 rockers, so cam lift will be .581 with the rocker ratio.
Comp calls for a 924 spring which is
1.509" OD dual spring
112 lbs. @ 1.900" installed height
355 lbs. @ 1.200" open
347 lbs rate
Will the cam live with the higher pressures on the trick flow springs? Comp say it's within tolerance.
Frankly the comp spring 925 is nearly identical to the PAC spring on the Trick Flow heads.
Comp also calls for a 10 deg lock, the TFS heads have a 7 deg lock. Do I need to make the upgrade? I am not seeing a reason, but that's why I'm asking.
Any help would be appreciated. I think the old break in with just the dampener and outer spring may be the ticket as well.
Thank you in advance!
.650 max lift
347 lbs rate
