Weiand 7511
Monkeymaster
10:56 AM
Iowa
Hello,
I have a Weiand 7511 single plane intake for my 383 or my 400.
Can anyone give me a report on their expirience good or bad with this intake.
I plan on mid grade budget/mild rebuild in a 66 charger with auto and 3.91 gears.
Holly 750 vac 2nd
Mild head work
Let's say mopar 509 lift cam
10 to 1 comp
This will be a street car, no strip.
I ran that manifold years ago in a similar combo. I actually still have it . It worked well. Not soggy on the bottom end but breathed well enough to put the car into the 11's with just a deep port match.
Mopar .509 lift cam is essentially obsolete unless you have it already (Imho too much duration for a street 383)
which heads? 66 heads?
can you estimate head flows
stick or auto if auto 66 trans (small input shaft?)
stock stall? HP/ Magnum Stall or?
what exhaust?
