what do you guys run for the speedo??
greenmonsta79
10:30 AM
Brazil,IN
I was looking at the connections on the Hotwireauto harness and one is the Speedo, I really had not gave it much thought until now, I would like to keep my stock Rallye gauges in the Charger I was thinking about using a stock Dodge Ram speedo and swapping the faces and modifying it to fit. What are you guys running?
I still have the original and it hasn't clicked a 10'th in over 25 years:rolling:
Electric speedo is what I'm using. You could get the gps style speedo, or there is a box that takes the signal and converts it to a mechanical signal and use you stock gauges. I thinks it's called x caliber or something like that.
Autometer Pro comp throughout istrument cluster.Have it assembled & cost less than having factory gauges fixed & refaced but am not ready to put in car yet.Put it on a 3/16 alluminum plate.Also you can put each gauge where you want them.If I ever decide to go back original can just swap out as a unit.
stock gauge - I am running a TKO trans so it has a mechanical speedo output
