What is the easiest efi setup for a carb dummy?
hudsonhornet7x
8:41 PM
Plumer, Pa
I am looking for an easy efi conversion. So far I have seen the MS3 hemi box and the holley hp efi. Should I consider anything else. Self tuning is important as I have NO idea how to tune efi. Thanks!
check into fi-tech fuel injection. its in one of the latest mopar magazine. i have seen it on tv when they built a 500ci stroker mopar motor. completely self learning computer is built in side of throttle body. i believe its good up to 600hp. everyone says its a badass setup. hope this helps ya out. MOPAR BABY.
Holley came out with the sniper as of today. Looks like a good easy setup.
I installed a FAST EFI system. It was not easy, but most of the issues related to an ECU problem. I hate to say it, but I don't recommend it. My system also controls timing though, so that added some complexity.
An EFI system, regardless of what you choose, needs to be thoughtfully and carefully installed. Don't take short cuts and I bet you'll be fine with most systems out there. I have heard good things about the FITech system from a coupe of guys. I think this system builds the ECU into the throttle body, which minimizes wiring hassles.
Good Luck,
Hawk
Thank you guys for the help. My cam has a 108 lsa so I hope one of these systems can handle it.
We have a fi-tech on order. It looks really simple to install and configure.
FI for a tunnel ram? Man, I have two pairs of TR carbs and well, I'm going to do my best to use them one more time lol
I ordered my fitech system awhile ago for my 318. My only complaint so far is how much they are backordered!
