What is the largest rear wheel size you for a stock 65 coronet?
Just take your time, think everything out, clean everything, go for it. Really really easy. Some welding required.
Howdy fellow mopar guys, I`m putting together a 65 coronet street strip car and wanted to pick your brains on what is the biggest tire / wheel combo I can put on the back of this car. I read some of the post regarding this and a fella called Super Stock said he runs 15x10s with 6.5" back spacing with 28x10.5 MTs on his with stock spring location and no mods to the wheel well. Can someone verify that for me. My car is all stock at this point and I dont want to cut or modify this car at all. Any feedback would be greatly appricated... Any photos of your set ups would be a big help too if it aint to much trouble...
:icon_fU:
I have a '65 Coronet. I have M/T Sportsman's on it size 275 x 60 x 15 on 8" wide American Racing Torque Thrust D's with standard factory backspacing. There have been NO modifications to the springs.......or min-tubbing. I have about 1" of space on the inside and outside of the tire/wheel when mounted. Perhaps a custom back-spaced wheel can be ordered to permit the use of a larger tire...but.....how much will you gain vs. $$$ spent? Hope this helps.
Thanks for the help, bigtime, but this thread is eight years old. I think he has probably made his decision .
Dont worry, ive commented on a twelve year old thread without noticing, lots of us have done it. Lol.
Food for thought , Cragar S/S 08/61 wheels look great on Mopars . A lot of folks do not know that Cragar has a Custom shop that will build you a wheel with the needed back spacing you might need . Go to the Series Gragar 08/61 S/S wheel site , on the top you will see Custom Shop . Click on it and will will take you to the custom shop . Cost of wheel plus $50.00 will get you a custom wheel . Just a reminder a 10 inch wheel will end up at 11 inches due to 1/2 lip on each side of wheel . I found about this by ordering but made it work . Hope this helps somebody
The diagram above is incorrect. A 8” and a 10” wheel with the same back space will have the inside of the rim in the same location.
Reading all these posts, I'm just going to ask what might seem redundant but I want to be sure. I have a 65 Coronet with stock body wheel wells and spring locations, I want to run 255/60/15s on 8" wide rims and 4 1/8 backspace. Will that work without rubbing on either side of tire?
I think it will. (Note... think!)
Frankly, I'd like to see more backspace than that. I'd feel more confident.
I've got a 255x70x15 on an 8" wheel with 4" bs, but it's on a 62. Close to the fender, lots of room to the spring. 4.5 bs would fit better.
I run 275 60 15 4.5 back space 1 inch over stock height springs no issues.
My old rims and tires are in storage. Next time I stop by I can measure the rims and check the size of the radial tires. I didn't pay much attention since I knew I was gonna chang'em.
Here's a pic of the 10" Cragars and radials.
Looks like a 15x10 standard's. I would have to look them up but they are close to 5" backspace. They weren't the "deep dish".
Just an FYI, I did instsall 255's with a 4.25 backspace and they fit fine.
255/60-15 with 4.25 backspace fits fine. No rubbing with room to spare.
if I could have found some nice oe looking chrome reverses they’d be on my car. I hate those dual pattern wheels.
My cheater slicks are 275/60. No problems but I have 1 inch over stock height springs with an extra half leaf from Espo.
