What rims are these and what center caps do they take
chargers777
12:24 PM
nashport ohio
Center bore outside is 3 inches. Inside is 2.75inches making it hub centric for Mopar. What caps can I use? Can't find any push on that fit a 3 inch bore. What brand of rim are these? No markings on back of rim.disregard center caps in pic. They won't fit over the hub of the car.
Deflate one tire. A lot of times the manufacturer's name is cast into the barrel of the rim.
3" chrome freeze plug?
Seriously, Google 3" mag wheel center caps. You need push-in from the front caps.
i believe it was mentioned the center bore was 2.750. is that the wheel center bore or the cap center bore ?
regardless, it's no wonder the combination won't fit over the hub, because that is a ford register size.
the mopar register size is 2.810.
:drinks:
