Satellite72
Two questions I'd like to ask... After having fixed all of my electrical demons, I'm finally ready to install my carb/intake and am going to replace the water pump while I'm at it. Since my 72 Satellite has an air conditioning unit, it looks like I'll have to remove the compressor in order to change out the other equipment (that is unless one of you knows another trick to get away from that). The A/C hasn't been used in 10+ years because of low R12, however just to make sure it would work I jumped the low pressure switch for a minute causing the compressor clutch to kick in, and it did. For my first question... If removed, I am faced with a decision when getting it back together of recharging with some R12 that my father-in-law has half a tank of or converting it to R134a. Just curious what you guys would do? My other question deals with the R134a conversion. I've read on another thread that "seals" have to be replaced when going from R12 to R134a due to higher pressures... are we talking about replacing seals located at each compression fitting or something inside the compressor? Thanks Guys!
