What's It Worth? (4 Speed Setup)
Zeppelin264
3:46 PM
San Diago
I'm just curious your opinion on what a used 833 23 spline (pulled working fine) 4 speed, 11" bell housing, 143 tooth flywheel; setup for a cast crank 440 & crossmember would be worth? I also have 2 shifters(Non console) & all the Z bar stuff as well that would go along with it.
All you'd need is the floor hump, clutch & pedals for a complete 4 speed swap. This was out of a 68' Coronet with an 8-3/4" rear end. The pedals are still in the car, I just haven't found time to swap them out. I even still have the driveshaft from this setup as well... haha
I was trying to add up what I would pay for each item and came up with about a thousand. I'm sure I'm low as I tend to be conservative until its something that I have to have.
