Whats the correct torque for these bolts??
John Tipps
10:47 AM
Dallas Tx
I maybe should go to a Plymouth forum but here goes- I did a front disk conversion on my 66 Charger years ago with E body parts (spindle, caliper bracket and dust shield) and I'm doing brake job and googled the torque on these caliper bolts and im getting everything from 35-55+ torque specs, can someone let me know what's correct and should I use Lock Tite?
All that you are doing is holding the pin tight, the lower minimum 25 ft lbs would be fine.
