Where did you mount your vacuum canister?
Rocketman
4:13 AM
Kentucky
My Comp Cam canister came today and all I could say is wow! that thing is huge.
Would appreciate all pictures of where it could be mounted.
thanks
thanks
I have mine on the passenger side corner of the engine compartment, by the firewall. It's for a '70 383 air grabber car.
Take the fender off and mount it in the void under the radio antenna. Too big for that?,mount it in the trunk. Just make sure you use VACUUM hose. Regular hose will collapse.
I mounted my factory cannister for the A/C switch right in between the door hinges on the passenger door of my 71. Just drilled a couple holes and put it there, not much to it. Doesn't interfere with opening/closing the door at all. This way it's also hidden behind the plastic factory inner fender splash shield. Stock location is under the battery tray BTW for my 71 with factory A/C.
