resq302
My chargers power disc bendix brake booster started leaking / hissing towards the end of last season occasionally when I stepped on the brakes hard. Is there anyone in particular I should stay away from? Some better than others?
While it is out, I'm considering redoing the master cylinder also just so I don't need to worry about it leaking onto the freshly redone booster. I've heard people can have the cylinders sleeved with either brass or stainless to prevent corrosion inside the bore which would end up damaging the seals and causing a leak. Is one material better than the other with DOT 3/4 brake fluid?
