Banzaiii67
Recently replaced an Edelbrock Carb with a Quick Fuel SS680. I'm using the Quick Fuel carb base gasket that came in the box. I'm getting a whoosh sound under hard acceleration that wasn't there before.
I did change out the air cleaner base to a 1.25" drop with a 3" filter, and capped off the air inlet hole to connect to the valve cover breather.
Pretty sure it's the carb gasket..I'll run a unlit propane torch under it tonight to check.
1st time using a Quick Fuel or Holley type carb, wasn't sure if this was normal or not. Vacuum is slightly lower than before, was 11.5-12" in gear, now it's 9.5-10"
