Why the 33" power steering pressure hose?
1963JAM
11:08 PM
Worcester County Massachusetts
Couple questions on this issue. High pressure line leaks, so looking to replace it. Why is the replacement line so long for the 12"s from the pump to steering box? Is this Federal power steering pump correct for a 1966 Satellite? First pic is how the pressure line was connected, up over the shock attachment. Second pic is what I've seen posted here on FBBO for line position and third pic shows return line being pushed into pump pulley by the pressure line pump 90 connector. Fourth pic is Mopar parts manual which shows a 90° connection on return line at the pump. Can't find this anywhere in aftermarket world, of it is even a thing this car had.
Is there a better hose option? Have one custom made? Still have to wonder why aftermarket is 33"s long, is there a hydraulic reason?
Thanks and happy New Year.
I read somewhere that some pressure hoses had to have some bends in them to reduce resonance/humming in the system.
I'd like to know how that actually works.
You have a TRW pump, yes it looks original. They had the long lines from the factory. We don't know why, but it is so.
The engine and pump moves and the box does not so length is good.
That return line routing is horrible. Should curve to the rear not the front, way to close to the belt.
I think the first pictures hose arrangement is similar to the factory arrangement.
I've never heard nor seen the 90 degree on the return line at the pump reservoir
Here is a picture of how mine is routed. I replaced the original hoses myself, so I believe this is the factory routing.
The second picture looks like my 67 GTX is outed - big loop under the battery tray. I’ve often wondered why so long myself or if it was an incorrect replacement. Hadn’t thought about routing the loop to the rear.
Wish I could see what the steering box connection looks like. The way the hose sweeps down the inner fender to the box makes me think that connector is not a 90° bend.
I think your right... Here's a web search of a company that make a fitting to reduce the vibration
Thanks. Educational insight. May explain the 33.75" length of these pressure hoses. Length may take place of the silencer mentioned in article. Much like the 15" and 30" length of the earlier short and long ram intakes. Those specific lengths give boost from the bouncing pressure waves on the intake stroke for different rpm ranges. Here I was thinking of having a custom hose made to shorten the pressure hose, but I'll stick with the 'yarder'.
New shiny heads are going on. The air cleaner was a 67 440 unit that someone had hacked the snorkels off of. I cleaned it up and it fits around the A/C perfectly.
