Wideband question
440+6
3:29 AM
Michigan
I was looking at some wideband meters to fine tune my six bbl setup and had a question about bung location, It looks like you can install almost anywhere, they even have a tailpipe sniffer type adapter.
My question is if it can be installed in the H pipe and be accurate, my idea is that I would get an average of both sides instead of only one side, dose this make sense?
I would install it as close to the engine as possible. Tail pipe sniffer is very disliked. You could also install 2 bungs right and left, however most people just use 1 and plug the other. Search for which side to install from other posts.
I bought a AEM gauge with the O2 sensor. Bought a 5 pack of bungs. Bought New stubs that bolt to the collectors and welded one bung on each one. I haven't installed yet, but I will test both sides individually( test one side and plug the other) then I will leave the sensor in the left side.IIRC that is the best place to keep it after all tuning is done.
I've used an Innovate for a few years, I've always put a bung in each collector.
