Widest rear rim and tire for 70 Bee.
toolmanmike
Henchman #2
Staff member
1:05 PM
Iowa
I searched through a few pages but didn't see an answer. What's the widest wheel and proper offset for the rear of a 70 Bee? What's a good sized tire that will fit without rubbing? thanks, tmm
With those huge wheel wells I think you can probably run just about anything you want.
I had 10 or 12 inch wide cragars with an incredible dish and 12" wide tires (either L 60 or M 50, can't remember).
No prob, no rub.
...and the 68-70 Dodge will take a larger tire than the Plymouth without issue.
so just guessing that 20" rims off a recent (2011) SRT8 Challenger will fit under the Coronet? Or will there be rub issues? Anyone?
biggest i have seen is (without mods) is a 22x11 rim with 305/35 22.
with mods i have heard you can run a 315.
i used to use a 15x10 with 295 50 15 and had heaps for room, heres a link you can have a look at to work out sizes.
http://www.rimsntires.com/specs.jsp?item=Wheel-Tire%20size%20comparer&sw1=225&ar1=60&bd1=17&rw1=8.0&et1=7&sw2=295&ar2=50&bd2=18&rw2=9.0&et2=1&text1=&text2=
http://vexer.com/68rt/old_outdated_badly_coded_old_old_old_wheelguide.html not a charger but pretty much the same
On my '69 'Bee currently I run 15X10 Mag 500's with a 5 inch backspace, Hoosier 295X60 X15's. No rubbing,inside or out, fills wheel well perfectly and corners like crazy, with a nice highway ride. In front, currently 15X7 Mag 500's with BFG 235X60's. Want to go to 15X8 Mag 500's and probably MT 245X60X 15's. Anyone know a proper backspace for front. 15X7's get lost in front wheel well.
'68 thru '70 B Dodges have larger wheel wells all around than same year Satellites. Have had both. 15X9 max for Satilite in rear.
SUPERBEE MARK
