will 275's fit on a 15x7 rim?
djais1801
7:32 PM
east side
just scored a good deal (in my opinion) on a set of cop wheels 15x7 w/ hub caps.
I just ordered 235 70 fronts and 275 60 rears for my current ralleys 15x7 front and 15x8 rear.
Will the tires I ordered fit 15x7's all around? I would hate to have to get a second set of tires too.
I have 275 60s on my 15x7 rallys and they do fit. I went with 245 60s in the front.
i located a set of 15x7 cop wheels and center caps for $200. good deal i think!
Here's a pic:
Not a real clear one - but this is all I have right now.
IMHO..the wider front tires look better than the 215's
A 275-60 really should be mounted on an 8" wheel. I've run them on 7's before but in order to get even tire wear, I had to run them with lower PSI and then they didn't handle as well as if they were on an 8" wheel. Inflate them to where they should be and you end up riding more on the center of the tread. Measure the width of the tread and they should be around 9" wide and the wheel should never be more than 1" difference either way. When I finally got 8" wheels, I could really feel the difference and it was much better.
