Window regulator question?
Terry Kitzman
7:31 PM
S.E. Iowa
Are the front window regulators the same on a 1966 Charger and a 1966 Coronet?
Yes, they are different as stated above. The door panel is padded on 66/67 Chargers therefore if you use a Coronet regulator which I understand will bolt right in, you will not be able to put the window crank handle on it.
Classic Industries Product numbers MM1088 and MM1089 but are only for 1967 Chargers (2 dr Bs)
Terry,
Your in box is full, I may have an original driver side regulator if you still need it
