Windshield rubber question
Darter6
8:57 PM
Nevada
Working on a 63 Belvedere, I believe the windshield is slightly different that the 64-65.
Question is will the 64-65 windshield rubber work on the 63 ?
No it will not! I have new gaskets for them! Tell me what you're working on and I will give you a price! I have some in stock, also it'll be less than you'll pay from any one else Get back to me via P.M. Thanks!
I'll let you know Steve. I'm sure you guessed by now I' have a new gasket for the 64-65 but have a 63 Car !!
Never fails,ain't got what ya need,but sure got the stuff that ya don't.... Thanks all !
The 62-63 B-Body hardtops, sedans, both two and four door applications take the Precision gasket WCRD 617. The 64-65 B-Body hardtops, sedans both two and four door applications use the Precision gasket WCRD 647. The 64-64 B-Body convertible application uses the Precision WCRD 647A. That covers the different applications with the correct gasket.
Doesn't fit for S-H-I-T on my 62.
It's bigger than the opening, bigger than the old gasket by a mile, and it's 2 inches past the edge of the window side, without the window slid into the gasket.
Old gasket was hard as a rock, so I trimmed it neatly, but can't reuse it.
What am I missing here?
20210902_194325.jpg 20210902_194315.jpg 20210902_194259.jpg 20210902_194018.jpg
So I'm told the Precision seal should have a label heat sealed into the bag.
Also, that sedan seals are larger, as in they don't fit "All" models. DMT sticker states otherwise. Yes, my first response was to call them but they were closed, and I will be calling tomorrow asap.
The I discover the sticker below the sticker, on a completely sealed bag. WTF!
Matt,
You have a 72 to 93 Dodge truck gaske, part number WCR 914, I bet. Look at the bottom label.
Richard
I called and the owner, Jim, answered.
Sending me correct seal overnight.
Sent pics, said he's never seen this before and the other 2 in stock do not have a sticker over a sticker.
Overnight, we'll see if it makes it here, but at least he is making the effort.
I always say, it's not always the error that matters the most, it's the response and recovery.
Like some, when I can't get someone on the phone at that moment, and it gets worse the more you look at it, it becomes extremely frustrating, but DMT is doing what they can at this moment.
He also stated, this windshield seal is the same one sold by everyone, as I asked if the more expensive brand was in stock I'll pay the difference.
Bag is completely different, not sure that matters, fits perfect.
Used the 3M bedding stuff, then went and grabbed windshield and cleaned it.
Supposed to be a pain in the butt job only professionals can do. Manual states to put in top first, not possible alone so I did bottom first.
Just the windshield install alone, seal already in, done in 55 minutes.
Nylon cord in windshield channel, hot soapy water, plastic scraper. After it was in, screwdriver used to lock a few stubborn parts of the seal.
