Windshield trim clips
70BurntRt
3:03 PM
Silver Spring, MD
Can someone tell how many clips were used on the front upper and sides of the front windshield and can you post a picture of the clip locations? I think my body guy maybe have relocated and or added a few. Thanks
Hi on my 68 Charger I have 3 on each side
8 across the top 9 on the bottom, I was not impressed by the “ Authentic Mopar” repop clips very bendy they don’t spring back, as I found out test fitting trim to them , if you bend them back they snap & break , luckily I saved a lot of the originals ,I was short about 6 so I spaced them apart, so at least I have one between the monkey metal, also the screw heads are larger than original , which made the F bombs drop ,I hope this helps you Cheers !!
Thanks for the replies. I noticed some cars have 8 across the top and some have 10. I just wanted to make sure my body guy didn’t put in any extra.
Jumping in on this old thread…
I have been battling the windshield lower trim installation for the 68 Charger. The top and side windshield trim went in without a fuss.
Studying the pics in this thread and other sources, I think the wrong clips were installed along the bottom. Attached are some close up photos from a few angles.
Can one of the gurus help me with:
1. Do I indeed have the wrong (to short) clips installed?
2. Does the windshield bottom use different clips than the top & sides?
3. Is there any way to remove the windshield and reuse the gasket, or should I just plan on trashing the gasket and buying new? Of course that includes resealing.
