Wing window identification
challenger6pak
1:55 PM
South Florida
I have some wing glass left over. I don't have a B or A body here to use to figure out which wing window fits what. The clear glass is slightly taller with the hinge hole in a higher location. Most likely it is B body. I wanted to check for sure before I sold them. Any help on which is which will be appreaciated.
I keep getting an error message on the photos. I'll try again a little later.
A post so worthy, it's posted 3 times?
If anyone knows the difference between A and B body wing windows, please let me know. Thanks.
If it helps I grabbed a couple quick measurements before I left the shop. B body (68/69/70) glass is about 11 1/2" long on the rear edge and the pivot hole is about 5" up from the bottom.
