Wing window pivot removal?
19polara64
8:16 AM
Brier, Washington
Can’t get the upper pivot out. What am I missing?
127E4D64-F8C4-47AD-91B8-196AE3DF7EDA.jpeg 79F74027-D822-40E6-9A65-CFB9E9582F63.jpeg
Pull back the rubber, is there a second rivet?
Never did an early B but 66 on there are two rivets holding the upper pivot in.
No idea, sorry about that. I'm sure someone will chime in.
Just redid a set you have to pull it out of the car the pivot is riveted to a channel that the screw you removed holds in. The entire vent frame will need to be disassembled
