scron1stmopar
New Member
Recently purchased a '63 Savoy MW. Early Nov. production date. My driver side light/horn harness is paired with the positive battery cable to the starter. Runs just above shock tower. There are no holes similar to the engine harness mounting as on the pass side. Did some early MW's not have the higher routing location? Also, the firewall hole that is below the drop resistor is a flexible patch cover instead of a plastic oval plug. Any comments? All other aspects are correct, and car is documented very well. Thanks.
