Wiring problem 1970 coronet
Masonmiller70
New Member
10:24 AM
Barre Ma 01005
Hi guys I’m having an issue with my 1970 dodge coronet that has a 360 with a 904 trans the car will turn over if I jump the starter relay and I have power to the ammeter but other than that I have no power to anything in the car ,ignition ,lights ect nothing at all . The disable link is good and motor will fire if I put direct power to coil but can not get any power to the ignition any ideas ?
No lights? Headlight switch is powered from the Ammeter output side, and is constantly hot - lights go on without the key. No start from the ignition - jump the starter relay ground wire after making sure the car is in park. You may have two problems.
The car will turn over if I jump the starter relay I already stated that and no the lights do not turn on at all have no power to anything
OK, I didn't know if you were jumping the main battery and starter wires or disconnecting and jumping the ground wire to the neutral safety.
You may have more than one problem...
For the first issue of having to jump the starter relay, I would suggest to trace the wires that go to the bottom of the starter relay to the neutral safety switch on the transmission...
On some cars the neutral safety switch has a connector by the firewall, also check that...
If you need a wiring diagram, you can download one for free here:
http://www.mymopar.com/index.php?pid=109
Welcome from NY.
You might want to ask your question in a different forum.
welcome to FBBO
maybe ask this in the general discussion forum
&/or the electrical ____ forums here
this is just a welcome wagon
for getting to know each other
share a few photos
not a Q&A tech section not as many viewers as the others either
good luck with your electrical problems
a year & Make specific Factory Service Manual
is the 1st thing you should invest in
