wiw 64 belvedere 426 street wedge
2:30 AM
toronto
ok you b body aficionados. fairly original car, 4sp, #s car, good shape, drivable. Sorry, no pics as of yet. what's it worth?
35k+ if its a numbered wedge car-Need pics
Gah , think I was off a bit as theres one on fleabay asking price 115, 000
http://cgi.ebay.ca/Plymouth-Belvedere-/390294174131?pt=US_Cars_Trucks&hash=item5adf5879b3
There is a world of difference in those cars. The link you provided is for a 426 A990 race Hemi car. The original poster is asking about value of a 426 WEDGE, not a Hemi.
Without detailed pictures and info on the subject car there is no way to give an accurate valuation of the subject car.
looking for a ballpark. 62k miles, car has a repaint over original panels, brightwork is good, glass is good, #s block, 4sp, 8-3/4, a good driver car, not a trailer queen. I won't hold anyone for there guesstimates.
this is the best I can give you at this time.
thx
so they can only really be date code correct.....? correct. Not matching #'s
Yes, just date code correct
426 wedge and a 4 speed, Belevedere, 64... Assuming it has a crossramed 426.. It would be a fair estimate to say $40-$60K high end... Just the motor should be worth about $9,000, 64 Belvedere in good shape is $15 to $20... So yeah, I would ball park it at $35K at least...
This would only be correct if it was a Max Wedge car or engine. I THINK this is a 426 street wedge that is not even CLOSE to those values.
You did not tell us if it is 2 door post/hardtop/4 door...what?
What's the difference between a 426 Max wedge and a 426 Street wedge?
1964 there were two differnet 426 wedge engines. The 426 street wedge that was a single cast iron 4 barrel engine with the log type exhaust manifolds and 10.3 to 1 compression. The 426 max wedge was a 12.5 to 1 compression dual 4 barrel cross ram, with the max wedge exhaust manifolds. Two completely differnt engine packages.
The 64 max wedge: http://www.moparmusclemagazine.com/featuredvehicles/b_body/1964_dodge_330/index.html
the street wedge: http://www.youtube.com/watch?v=VZs2aN542yc&amp
Also a big differnece in values as well. Hope this helps you. Matt
