Wobble from front
tlwesch
7:01 PM
New Jersey
Hey guys...looking for some help or things to maybe look at. When I get my car up to about 35-40 MPH I get a wobble or shaking from the front passenger side tire. Any ideas what I should look at? Is it possible the spindle is bad or bearing?
Look at the tire. Jack it up and grab the tire at 9 and 3 and give a shake. See if anything is loose. Then grab at 12 and 6 and do the same. See if anything is loose.
Most likely either wrong bearing end play, or one of the bearings going out. (Unless your lugnuts are loose!)
You ever re-pack the wheel bearings? Sounds like it's time. And you'll get a look at the bearings, to see what shape their in. Also suggest doing BOTH fronts, inners and outers, tossing new seals in on the deal.
Makes a bad day...when your wheel falls off!
Thanks for the suggestions. Changing the water pump and having the radiator re-cored. Going to pick up a factory service manual and start on this next.
At that speed, I'd suspect a tire being one of two things.... Flat spotted from sitting for too long or a broken belt. A quick way to check it out is to move that tire to another location and see if the wobble moves to that location, too.
If it was a wheel balance problem, you most likely wouldn't notice it until above 50 mph.
