WTB 1960's B body (complete running car)
fwi
2:21 AM
BHC Arizona
Feedback: +0 / =0 / -0
Looking for a decent Plymouth or Dodge that meets the following criteria:
1960 to 1969 only
engine size unimportant as long as it runs well and no fluid leaks
stick shift
NO RUST
daily driver quality OK
No projects please.
Will pay $10 to 15K cash for the right car.
Prefer something not too far away from Fort Myers FL area.
What is the pedal setup out of and how complete is it?
pedals are out of a 64 Savoy, still in mounting bracket and I think the return spring is still there. I even have a couple of brackets for the pivot ball that mounts on the inner fender side. the rod that goes thru the firewall is there too
Unfortunately, changing a 727 over to a 4 speed in a Mopar is not an easy task (see posts about this subject on this site).
I really like your car and would like to make a deal.
I am planning on towing it 4 wheels down behind my RV. The only real easy way of doing this is towing a stick shift, however, "IF" I disconnect the driveshaft, it can be done......unless someone knows of a way to tow an automatic.
what is the difference if you tow a stick or automatic flat? on a long distance flat tow I would pull the drive shaft anyway.
I have all of the brackets for under the dash for the stick set up as I parted out two 64 Savoys that were stick cars
The engine room looks a little funky in the photo...........any problem areas in there that need attention, any oil or fluid leaks?
Also, what city/town are you located?
engine compartment is dirty, minor surface rust by the steering column.
135,000 on the motor couple drips, trans fresh rebuild
car is in Millstone Twsp NJ
