Yellow High Beams / Driving Lights
0DegreeEngineer
10:32 PM
Fountain
Does anyone have a part number or know where i can get yellow high beam bulbs, not the Holley housings but true yellow glass bulbs or do I just need to use a stained glass paint to get the desired look? Below picture for reference.
Wagner 4412A $8.99 at Summit. The little indexing bump doesn't match the headlight bucket notch so you will have add another one and the wires attach with screws, which is an easy adapt.
I used these from octane lighting. They don't fit the headlight buckets as well as I would like. But they are glass. There about $100 for the set of 4.
70 RR do you have a picture of these installed?
I have always just used gold anodizing paint and spray with multiple coats.
6PKRTSE how did you got a translucent color from that? It looks like it would just block the light in the lense or was it light coats?
some 40 years ago, I got a set of 4 plastic clip on covers I believe from J.C. Whitney.
Multilopes To bad they are not still available
Outlaw525 should mean just add another clocking indent correct?
Question: does your state, in which the vehicle is registered in, have any lighting requirements (color, sealed beams, halogen, etc)? Some states did/do and any safety requirements? At one time, PA did...only OEM was allowed....any thing else was not permitted by state annual inspection requirements....Just a thought.....
BOB RENTON
I just checked Amazon & found something like I had: One is 6" & the other is 9"/ I also saw a 7" . I only looked at the first page; there might be more!
I searched using (amber plastic automobile headlight covers)
I wont argue the diminished lighting capabilities of the yellow lights. I just like the look, I rarely if ever use high beams even on my modern cars. I do have regular bulbs I run also.
