Rodzilla
New Member
I have the opportunity to pick up a '68 Road Runner that someone has started to restore but gave up. The body is all intact and metal is straight and in a primer state. Some of the trim is there, but not in great shape, the interior is gone except for dash. He does have most of the panels for recovering. Motor and trans are gone but it is rolling, I'm assuming its the original 8 3/4" under the rear but not confirmed yet. I've only seen pics of body. I'm not a body/paint guy, so I'm happy its close to being paintable. I enjoy wrenching on projects but concerned that finding a numbers matching or date matched drivetrain might be difficult. Car came with the 330HP 383 (Commando?) and a 4 speed. According to the Fender tag its an air conditioned car.
The seller is asking $7000 for the car, I'm thinking I might get it for $5500 or $6000. Would it be worth it to restore. I'm guessing if done right this car could appraise out at $45000. But would also cost close to that to get it done properly. My biggest concern is that the VINs second digit is an H and not an M, even though the fender tag decodes as a Road Runner. Was there ever descrepencies between VINs and Fender Tags? Has someone swapped out the Fender Tag maybe?
Sorry for the long post and thanks for any input you experts might have! Below is what I decoded off the Fender Tag and VIN infor that the seller sent me.
FENDER TAG DECODED
CAR: Plymouth RoadRunner 2 Door Hardtop
ENGINE: 383cid 4-bbl HP V8
TRANSMISSION: 4-Speed Manual Floor Shift
TIRES: F70x14 Red Sidewall, Steel Belted
MODEL YEAR: 1968
BUILD DATE: May 27.
AXLE: 3.23 Rear Axle Ratio
INTERIOR: High Trim Grade, Vinyl Split Bench Seats. Black Interior.
PAINT: Monotone Bright Blue Metallic Paint.
OTHER: Black Upper Door Frame Color.
MOLDINGS:
25: Drip Rail Mouldings
ABC OPTIONS:
P6: Rear Seat Speaker
R1: AM Radio
T7: Tachometer
abc OPTIONS:
h7: Fender or Hood Mounted Turn Signal Indicators
u1: Sold Car When Built (Somebody Ordered It)
w6: Build to Spec's for Canada
VIN: RH23H8A307327
R: Belvedere / Satellite
H: Satellite (1968- 70) but should be M: Road Runner (1968-74) to match fender tag
23: 2 Door Coupe
H: 383 c.i.d./330hp or 335hp 4-bbl V8 (1968-69)
8: 1968
A: Lynch Road, Detroit, MI
307327: Sequential production number starting with 100001
FENDER TAG DECODED
MODEL YEAR: 1968
BUILD DATE: May 27.
MOLDINGS:
ABC OPTIONS:
R1: AM Radio
T7: Tachometer
abc OPTIONS:
VIN: RH23H8A307327
23: 2 Door Coupe
8: 1968
