Wet Sanding and Buffing
MoparMuscleGuy
10:18 PM
Cocoa, FL
Hello, I just finished painting, basecoat/clearcoat, my hemi scoop today and it turned out beautiful. I had to paint it outdoors and a fricken tiny bug flew into the base coat. I would like to wet sand this area out and buff it. How long do you wait to wet sand and buff? I believe 2000 grit would be good but what polish should I use to buff it out after sanding? Thanks, Chrisopher
wait at least 24hrs, cut it with 1000, then 2500. Any good compound will work. 3M should be easy to find, I use yellow foam pads.
and when you finish... come down to Juno Beach and bring some B5 Blue with ya...
Depending how nasty the bug defect is will dictate the starting grit. 1000 is a little aggressive (sorry Adamr) 1500/2000 is a safer approach. I would use 1000 on a run to knock it down) Like Adamr said, most compounds will work. After 2000/2500/3000 (not always 3000) I use Farecla G3 (coarse) with a blue foam pad followed by G10 (fine) with a white foam pad. Mirror finish!
If you haven't already started, post a pic of before!
Had the same thing happen to me, I agree start with 1500/2000.
Your correct, I wrote 1000, 2500, should have been 1500,2000.
Thanks for the help guys. I probably will not get to it for a couple more days due to my work schedule. Here's a few photos of the Hemi Scoop. MMG
Hi Mopar,very nice car ,i like the floor in your garage ,What type of flooring is it,I dont have a hoist so can a floor jack be used on it
The floor is a VCT with a high gloss sealer. It's holding up very well after about 2 years of use. If you wanted to use a floor jack, I would use a piece of wood under it to protect the tile.
