Propwash
- 3:20 PM
- Oct 29, 2009
- Island of Misfit Toys
I agree with Cranky, drums are fine until they get heated up. The master for drum and disks should be of a different bore size no matter what MP tells you. Even autozone will have three different bore sizes for our cars
GTX Ken is right....Also there is a difference in the power assist ratio between drum and disc booster's. I just went through this myself with dealing with Right Stuff Detailing.
Also, keep in mind you will need to install a proportioning valve and then probably a 10 PSI residual valve for your rear drums once you go to power disc. I don't know off hand if your distribution block from a manual drum car will work with an updated power disc system. You could kill two birds with one stone and buy the Wilwood dist. block/prop valve combo for $60 bucks.
