combatsp
- 11:59 AM
- May 16, 2011
- South Williamsport, PA
Hi,
I'm new to the site. I am building my first performance engine. Well, my first engine of any kind really. I bought a 440 (.030 over) off C List already built to slightly above stock specs. I am putting on Stealth heads(CNC ported). I figured I would try them out after a lot of research and reading reviews. The cam was a .480 lift and I am replacing it with a .545 lift comp cam(hydraulic flat tappet). It has Crane gold roller rockers 1.5. The intake on the engine had an out dated Edelbrock Streetmaster and I am replacing it with an Edelbrock Performer RPM. It came with a 750 Holley and I will be swapping my 800 Eddy from my 383 to the 440. It has Speed Pro pistons, 440 source rods, double timing chain and a steel forged crank all of which I am leaving in.
I am currently researching fuel pumps. I think I have narrowed it down to the Edelbrock mechanical fuel pump that the company recommends for use with the 800 CFM Eddy carb. It doesn't require a regulator. I believe it will support my engine just fine.
The engine will be going into my 1968 charger. It has a 727 reverse manual valve body. I believe the stall converter is 2400rpm which will need to be upgraded. 3.55 gears in the rear which will need upgraded. I also put in a 4 point harness to replace the lap belts. I will be putting Nitto drag radials on.
My goal is to get into the high 11's for some bracket racing. So far I have torn the top end apart and installed the cam and heads. Not too much further to go.
